show lldp
show lldp {port [all | port_list]} {detailed}
Description
Displays LLDP configuration information for the specified port or ports.
Use the detailed keyword to display the configured VLANs on the port and the enabled VLAN-specific TLVs.
Syntax Description
all Specifies all ports on the switch.
port_list Specifies one or more ports or slots and ports.
detailed Shows information on the configured VLANs on the port.
Default
N/A.
Usage Guidelines
Use the detailed variable to display information regarding configured VLANs on the ports and any enabled VLAN-specific TLVs.
The following example displays LLDP configuration information for the switch:
# show lldp
LLDP transmit interval           : 30 seconds
LLDP transmit hold multiplier    : 4  (used TTL = 120 seconds)
LLDP transmit delay              : 2 seconds
LLDP SNMP notification interval  : 5 seconds
LLDP reinitialize delay          : 2 seconds
LLDP-MED fast start repeat count : 4
LLDP local management address    : VLAN Chicago (10.127.2.30)
LLDP Port Configuration:
Port    Rx        Tx        SNMP          --- Optional enabled transmit TLVs --
Mode      Mode      Notification  LLDP   802.1  802.3  MED   AvEx  DCBX
1       Enabled   Enabled   --            --D--  ---    ----   ----  ----  IB
2       Enabled   Enabled   --            --D--  ---    ----   ----  ----  IB
Notification: (L) lldpRemTablesChange, (M) lldpXMedTopologyChangeDetected
LLDP Flags  : (P) Port Description, (N) System Name, (D) System Description
(C) System Capabilities, (M) Mgmt Address
802.1 Flags : (P) Port VLAN ID, (p) Port & Protocol VLAN ID, (N) VLAN Name
802.3 Flags : (M) MAC/PHY Configuration/Status, (P) Power via MDI
(+) Power via MDI with DLL Classification for PoE+,
(L) Link Aggregation, (F) Frame Size
MED Flags   : (C) MED Capabilities, (P) Network Policy,
(L) Location Identification, (p) Extended Power-via-MDI
AvEx Flags  : (P) PoE Conservation Request, (C) Call Server, (F) File Server
(Q) 802.1Q Framing
DCBX Flags  : (I) IEEE 802.1Qaz DCBX, (B) Baseline v1.01 DCBX
The following example includes detailed information on the LLDP configuration for port 1:1:
# show lldp port 1:1 detailed
1:1     Enabled   Enabled   --            --D--  ---    ----   CLP-  ----  IB
VLAN: Default                           -----  ---    ----   ----  ----
VLAN: voice                             -----  ---    ----   ----  ----
AvEx Call-Server: IP Address(es)=10.0.0.20, 10.0.0.21
AvEx File-Server: IP Address(es)=10.0.0.20, 10.0.0.21, 10.0.0.22
AvEx 802.1Q Framing: Mode=tagged
MED LCI: Location Format=ECS ELIN based
1234567890
MED Policy: Application=voice
VLAN=voice, DSCP=40
DCBX: Priority 4, iSCSI
DCBX: Priority 3, FCoE
DCBX: Priority 3, FIP
(Q) 802.1Q Framing
The information on fast-start repeat count, MED, AvEx, and notification was added in ExtremeXOS 11.5.
An additional flag was added for PoE+ in ExtremeXOS 12.5.
The display was updated for DCBX in ExtremeXOS 12.6.
Management IP address information was added in ExtremeXOS 22.4.
Platform Availability
